Linux program to receive hexadecimal values
Postby alextreme » Tue 23. Aug 2011, 09:53
I have a PEAK CAN/USB interface, I used PCAN-View in Windows (1 Mb/s) to receive some DATA from my CAN interface and it works. I can receive some hexadecimal value.
Now I would like receive the same value using Linux, I have tried "receivetest" present in the CD but I have only this result:
root@FHEEL:/home/aau/Desktop/test# ./receivetest -b=0x0014
receivetest Version "Release_20090203_n" (http://www.peak-system.com)
receivetest comes with ABSOLUTELY NO WARRANTY. This is free
software and you are welcome to redistribute it under certain
conditions. For details see attached COPYING file.
receivetest: device node="/dev/pcan0"
Only standard frames are accepted, init with BTR0BTR1=0x0014
receivetest: driver version = Beta____20110223_n
^Creceivetest: type = usb
Serial Number = 0xffffffff
Device Number = 0
count of reads = 0
count of writes = 0
count of errors = 1
count of irqs = 116906
last CAN status = 0x0020
last error = 0
open paths = 1
receivetest: finished (0).
Thanks.
Best.
alextreme
Re: Linux program to receive hexadecimal values
Postby M.Maidhof » Tue 23. Aug 2011, 10:03
you are using /dev/pcan0 which is a PCAN-PCI card, please check the output of receivetest :
please use:
./receivetest -f=/dev/pcan32 -b=0x0014
when you want to use PCAN-USB with 1Mbit/s.
It will always be helpfull to have the cat /proc/pcan output to see which driver version and setup you are using.
Postby alextreme » Tue 23. Aug 2011, 13:04
M.Maidhof wrote:Hi,
please use:
Thanks.
But in /var I don't find pcan32.
Best.
alextreme
Postby alextreme » Tue 23. Aug 2011, 13:56
I think that in my case pcan0 is the USB:
root@FHEEL:/sbin# cat /proc/pcan
*------------ PEAK-Systems CAN interfaces (http://www.peak-system.com) -------------
*-------------------------- Beta____20110223_n (7.0.0) ---------------------
*--------------------- 1 interfaces @ major 252 found -----------------------
0 usb can0 ffffffff 000 0x0014 00000000 00000000 0000000e 00000000 0x0000
I found also:
(9*) = From kernel version 2.6 on the behaviour during assignment of the
„minor“-numbers is being changed through the kernel parameter
„CONFIG_USB_DYNAMIC_MINORS“. When „CONFIG_USB_DYNAMIC_MINORS“ is
set, the first free „minor“-number is assigned to from 0 on. Mandrake distributions uses
this configuration.
Thanks.
alextreme
Postby alextreme » Tue 23. Aug 2011, 14:48
I solved installing in an other Linux system, but still I can't read data:
ale@ubuntu:~/Scaricati/peak-linux-driver-7.3/test$ ./receivetest -f=/dev/pcan32 -b=0x0014
receivetest Version "Release_20090203_n" (www.peak-system.com)
receivetest: device node="/dev/pcan32"
receivetest: driver version = Release_20110728_n
Device Number = 255
count of reads = 0
count of writes = 0
count of errors = 0
count of irqs = 18884
last error = 0
open paths = 1
Device Number = 255
count of reads = 0
count of writes = 0
count of errors = 0
count of irqs = 98017
last error = 0
open paths = 1
Thanks. Best.
alextreme
Postby M.Maidhof » Wed 24. Aug 2011, 12:06
you have builded the driver for netdev (see can0 in cat /proc/pcan), but you want to use the chardev tools. This will not work. Please build the driver again with make NET=NO, to build a chardev driver. Please see the "BIG" info on our Linux website or in the pdf manual of the driver about that issue: http://www.peak-system.com/fileadmin/me ... /index.htm
Postby alextreme » Wed 24. Aug 2011, 13:38
Thanks. I changed the driver but using b=0x0014 I have this:
ale@ubuntu:~/Scrivania/peak-linux-driver-7.3/test$ cat /proc/pcan
*-------------------------- Release_20110728_n (7.3.0) ----------------------
*---------------- [mod] [isa] [pci] [dng] [par] [usb] [pcc] -----------------
*--------------------- 1 interfaces @ major 251 found -----------------------
32 usb -NA- ffffffff 255 0x001c 00000000 00000000 00000000 00000000 0x0000
ale@ubuntu:~/Scrivania/peak-linux-driver-7.3/test$ ./receivetest -f=/dev/pcan32 -b=0x0014
Device Number = 255
count of reads = 0
count of writes = 0
count of errors = 0
count of irqs = 38022
last error = 0
open paths = 1
I found that changing b to b=0x0013 I have this result:
ale@ubuntu:~/Scrivania/peak-linux-driver-7.3/test$ ./receivetest -f=/dev/pcan32 -b=0x0013
Only standard frames are accepted, init with BTR0BTR1=0x0013
537983.242 receivetest: m s 0x00000000 4 00 00 00 08
receivetest: pending CAN status 0x002c read.
539031.818 receivetest: m s 0x00000000 4 00 00 00 08
receivetest: pending CAN status 0x0028 read.
540080.394 receivetest: m s 0x00000000 4 00 00 00 08
541128.970 receivetest: m s 0x00000000 4 00 00 00 08
542177.546 receivetest: m s 0x00000000 4 00 00 00 08
543226.122 receivetest: m s 0x00000000 4 00 00 00 08
Device Number = 255
count of reads = 14
count of writes = 0
count of errors = 14
count of irqs = 38604
last error = 0
open paths = 1
I don't know what to do. :cry: Using PCAN-View the system read the values without problem.
Thanks.
alextreme
Postby M.Maidhof » Thu 25. Aug 2011, 10:33
do you know what -b=0x0013 means? This is a baudrate of 1142kbit/s.....
That is why you will receive the status messages (busheavy) from the module, because you are using a wrong and even for CAN undefined baudrate >1Mbit/s.
Sorry, but the way you will solve that problem is not the right way...
Please tell me what kind of CAN frames you have on the CAN bus? Do you use standard or extended frames?
Postby alextreme » Fri 26. Aug 2011, 10:30
I was thinking that b=0x0013 was a baudrate > of 1 Mb/s, I just posted that result.
I am using standard frame and using PCAN-VIEW I have not problem this is a trace file of PCAN-VIEW:
;$FILEVERSION=1.1
;$STARTTIME=40781.4352321412
; C:\Users\Maurizio\Desktop\Test.trc
; Start time: 26/08/2011 10:26:44.057.x
; Message Number
; | Time Offset (ms)
; | | Type
; | | | ID (hex)
; | | | | Data Length Code
; | | | | | Data Bytes (hex) ...
1) 0.0 Rx 15555555 8 55 55 55 55 55 55 55 55
2) 0.1 Rx 15555555 8 55 55 55 55 55 55 55 55
3) 0.3 Rx 15555555 8 55 55 55 55 55 55 55 55
4) 0.4 Rx 15555555 8 55 55 55 55 55 55 55 55
5) 0.5 Rx 15555555 8 55 55 55 55 55 55 55 55
6) 0.6 Rx 15555555 8 55 55 55 55 55 55 55 55
7) 0.8 Rx 15555555 8 55 55 55 55 55 55 55 55
8) 0.9 Rx 15555555 8 55 55 55 55 55 55 55 55
9) 1.0 Rx 15555555 8 55 55 55 55 55 55 55 55
10) 1.2 Rx 15555555 8 55 55 55 55 55 55 55 55
11) 1.3 Rx 15555555 8 55 55 55 55 55 55 55 55
Thanks.
Best.
alextreme
Postby M.Maidhof » Fri 26. Aug 2011, 12:49
no, this trace shows extended frames... :D
set -e option in receivetest to solve your problem.
Next
Return to Linux
cron
