bus speeds
bus speeds
Postby rwbruce » Fri 21. Oct 2011, 21:37
Greetings,
I have two USB/CAN devices connected to a Linux system. /proc/pcan shows devices can0 and can1. can0 must operate at 1-M bit rate and can1 must operate at 250-K bit rate. I passed option bitrate=0x0014 to the driver, so I am able to prove that the software and hardware are functional at 1-M bit rate using can0. I assume this sets both devices to the same rate. How do I set the devices at different rates?
Thanks.
Bill Bruce
Watlow Controls
Winona, MN, USA
rwbruce
Re: bus speeds
Postby M.Maidhof » Mon 24. Oct 2011, 10:02
please see our linux driver manual in pdf format on page 22:
example:
echo "i 0x0014 e" > /dev/pcan32
echo "i 0x011C e" > /dev/pcan33
You have to use the chardev devices to set the baudrate of the used Netdev devices.
Re: bus speeds
Postby rwbruce » Mon 24. Oct 2011, 18:36
OK. Thanks for the reply.
Bill Bruce
rwbruce
Re: bus speeds
Postby rwbruce » Mon 24. Oct 2011, 23:19
Michael,
Am I correct that the 'e' at the end of these strings places the device in 29-bit address mode?
If can0 is 1-M, 11-bit address and can1 is 250-K, 29-bit address, would the commands be as follows?
echo "i 0x0014 s" > /dev/pcan32
I'm looking at the table on page 32 of the manual.
Thanks.
Bill Bruce
rwbruce
Re: bus speeds
Postby M.Maidhof » Tue 25. Oct 2011, 09:52
Hi Bruce,
when you use 11Bit "standard" CAN frames you can just omit the "e" option.
echo "i 0x0014" > /dev/pcan32
Return to Linux
cron
