trying to install the latest driver under ubuntu 10.04 or 10.10 i just get an error in pcan_fops.c line 144:
- Code: Select all
In file included from /home/vmusr/Entwicklung/peak-linux-driver-6.24/driver/src/pcan_fops.c:144:
/home/vmusr/Entwicklung/peak-linux-driver-6.24/driver/src/pcan_fops_linux.c: In function ‘wait_until_fifo_empty’:
/home/vmusr/Entwicklung/peak-linux-driver-6.24/driver/src/pcan_fops_linux.c:56: error: implicit declaration of function ‘schedule’
/home/vmusr/Entwicklung/peak-linux-driver-6.24/driver/src/pcan_fops_linux.c: In function ‘pcan_ioctl_read’:
/home/vmusr/Entwicklung/peak-linux-driver-6.24/driver/src/pcan_fops_linux.c:143: error: ‘TASK_INTERRUPTIBLE’ undeclared (first use in this function)
/home/vmusr/Entwicklung/peak-linux-driver-6.24/driver/src/pcan_fops_linux.c:143: error: (Each undeclared identifier is reported only once
/home/vmusr/Entwicklung/peak-linux-driver-6.24/driver/src/pcan_fops_linux.c:143: error: for each function it appears in.)
/home/vmusr/Entwicklung/peak-linux-driver-6.24/driver/src/pcan_fops_linux.c:143: error: implicit declaration of function ‘signal_pending’
/home/vmusr/Entwicklung/peak-linux-driver-6.24/driver/src/pcan_fops_linux.c: In function ‘pcan_ioctl_write’:
/home/vmusr/Entwicklung/peak-linux-driver-6.24/driver/src/pcan_fops_linux.c:179: error: ‘TASK_INTERRUPTIBLE’ undeclared (first use in this function)
/home/vmusr/Entwicklung/peak-linux-driver-6.24/driver/src/pcan_fops_linux.c: In function ‘pcan_read’:
/home/vmusr/Entwicklung/peak-linux-driver-6.24/driver/src/pcan_fops_linux.c:498: error: ‘TASK_INTERRUPTIBLE’ undeclared (first use in this function)
/home/vmusr/Entwicklung/peak-linux-driver-6.24/driver/src/pcan_fops_linux.c: In function ‘pcan_write’:
/home/vmusr/Entwicklung/peak-linux-driver-6.24/driver/src/pcan_fops_linux.c:652: error: ‘TASK_INTERRUPTIBLE’ undeclared (first use in this function)
I try to compile with the following params:
- Code: Select all
DBG = NO_DEBUG
MOD = NO_MODVERSIONS
PAR = NO_PARPORT_SUBSYSTEM
USB = NO_USB_SUPPORT
PCI = PCI_SUPPORT
PCIEC = NO_PCIEC_SUPPORT
DNG = NO_DONGLE_SUPPORT
ISA = NO_ISA_SUPPORT
PCC = NO_PCCARD_SUPPORT
NET = NETDEV_SUPPORT
RT = NO_RT
VERBOSE = 1
Unfortunately i couldn't remeber how i fixed it at the last install...
Please, can you help me getting the driver running?
