Implicit declaration of function 'usb_reset_endpoint'
Postby ajay » Thu 8. Mar 2012, 13:39
I'm trying to compile the sources of the PCAN driver 7.4.
I get the following compiler warning:
.../peak-linux-driver-7.4/driver/src/pcan_usb_core.c: In function ‘pcan_usb_plugin’:
.../peak-linux-driver-7.4/driver/src/pcan_usb_core.c:1176: warning: implicit declaration of function ‘usb_reset_endpoint’
WARNING: "usb_reset_endpoint" [.../peak-linux-driver-7.4/driver/pcan.ko] undefined!
I use Ubuntu 7.10 Gutsy Gibbon
Kernel version: 2.6.22-16-generic
gcc version: 4.1.3
When ignoring this warning and tiping "sudo make install" and "/sbin/modprobe pcan" I get
FATAL: Error inserting pcan (/lib/modules/2.6.22-16-generic/misc/pcan.ko): Unknown symbol in module, or unknown parameter (see dmesg)
FATAL: Error running install command for pcan
with
[ 4107.921646] pcan: Unknown symbol usb_reset_endpoint
as last line of dmesg.
I know my system is quite old, but I have to use this kernel version! Could someone please help me?
ajay
ajay
Re: Implicit declaration of function 'usb_reset_endpoint'
Postby M.Maidhof » Thu 8. Mar 2012, 14:55
please see the following post:
viewtopic.php?f=120&p=603#p603
Postby ajay » Wed 14. Mar 2012, 11:01
Thanks now it compiles.
After make install and modprobe pcan I get the error
And dmesg says
[11330.540716] pcan: Unknown parameter `/usr/local/bin/pcan_make_devices'
The file exists and I gave the executable bit to it. What can I do?
Thank you,
ajay
ajay
Postby M.Maidhof » Wed 14. Mar 2012, 13:24
Hi
which PEAK CAN Hardware do you use?
Postby ajay » Tue 20. Mar 2012, 11:09
Hi
PEAK CAN Usb
best regards,
ajay
ajay
Postby M.Maidhof » Tue 20. Mar 2012, 17:34
then please build the driver for USB only:
make NET=NO PCC=NO PCI=NO ISA=NO DNG=NO PAR=NO
best regards
Postby ajay » Thu 29. Mar 2012, 14:27
thank you very much!
Somehow it worked and I could install the driver. (I also reinstalled udev...)
At least
cat /proc/pcan
gave me a good output.
Unfortunately I have another problem:
I need to have a new version of the driver on industrial pcs. But those pcs don't have any developement tools at all! So I took the image of the really old operating system Ubuntu 7.10 which HAS all the developement stuff I need and loaded it in VirtualBox. I put the compiled files into the Fedora system of the IPCs which have kernel-version 2.6.23.1-42.fc8
On the industrial pcs now I get
FATAL: Error inserting pcan (/lib/modules/2.6.23.1-42.fc8/misc/pcan.ko: Invalid module format
after modprobe pcan
and dmesg says
pcan: version magic '2.6.22-16-generic SMP mod_unload 586 ' should be '2.6.23.1-42.fc8 SMP mod_unload 686 4KSTACKS '
I know one shouldn't expect it to work, but is there a way to bypass the problem with a wrong kernel-version???
ajay
ajay
Postby M.Maidhof » Thu 29. Mar 2012, 15:03
the output of dmesg directly informs you about the problem! A kernel module will only work on the kernel it was build for. It is possible to cross compile our driver to a specific kernel. Here are the steps:
- call uname -r on your target system
- search for the kernel headers or source of that kernel in the internet or at kernel.org
- build our driver with the following option: make KERNEL_LOCATION=/where/my/kernel/source/is/located
Postby ajay » Thu 29. Mar 2012, 15:21
Thank you sir.
Another method would be
modprobe -i -f pcan
(But yes, unsafe etc ;-) )
I am so far that the driver loads automatically after rebooting. I first try it on this way.
ajay
ajay
Return to Linux
cron
