Starting Out with CAN_USB
Re: Starting Out with CAN_USB
Postby U.Wilhelm » Fri 26. Feb 2016, 09:55
Here some info from our Software Developers.
You also could use the OO PAS Version within Lazarus:
unit Unit1;
{$mode objfpc}{$H+}
interface
uses
  Classes, SysUtils, FileUtil, Forms, Controls, Graphics, Dialogs, PCANBasic;
type
  { TForm1 }
  TForm1 = class(TForm)
    procedure FormCreate(Sender: TObject);
    procedure FormDestroy(Sender: TObject);
  private
    { private declarations }
  public
    { public declarations }
  end;
var
  Form1: TForm1;
implementation
{$R *.lfm}
{ TForm1 }
procedure TForm1.FormCreate(Sender: TObject);
begin
  // Initialize the PCAN-Basic, Channel 1
  TPCANBasic.Initialize($51, TPCANBaudrate.PCAN_BAUD_1M);
end;
procedure TForm1.FormDestroy(Sender: TObject);
begin
  // Uninitialize the PCAN-Basic, Channel 1
  TPCANBasic.Uninitialize($51);
end;
end.
The sample project is available for download:
PCANBasicTest-Lazarus.zip
PCANBasic Sample Project for Lazarus
(133.42 KiB) Downloaded 171 times
U.Wilhelm
Postby docwat » Fri 26. Feb 2016, 10:28
Hi Uwe,
That is a mine of information and is most helpful. Just now, I have returned to the CAN_Basic UNIT1.pas.
I had built my own Initialise, Read and write routines which worked fine but I rather liked the ERROR options of Kenet Wagner's Unit1 code so I am simplifying them to replace my initial efforts.
I will certainly explore your information which may suggest still better options.
Lazarus is so close to Delphi that I have found no problems, bur I am not using your form where there may be differencies. Lazarus does provide DELPHI to Lazarus conversion routines but I have never tried them out.
As ever,
Vielen Dank
docwat
Postby docwat » Fri 4. Mar 2016, 15:40
Hi Uwe,
I have managed to get the CanBasic Unit to work fine within my Lazarus IDE so I can use the CAN_USB within our product.
The PeakView example throws up a few oddities which were partly resolved by using the Lazarus Delphi to Lazarus
conversion tool and I still have work to do to use a Lazarus.lfm Form Unit rather than the Delphi .dfm file. I have had to manually build the Lazarus.lfm and I rather think that the problems can be resolved by further work.
I am now pretty sure that I can complete writing my PC code using your .DLL which makes me extremely happy. The whole purpose of the work was to do away with a virtual serial comport. The DLL works far better with more simple code.
Vielen Dank,
Docwat
docwat
Postby U.Wilhelm » Fri 4. Mar 2016, 15:49
Cool ! Good Luck for your project !
U.Wilhelm
Postby gioazz » Tue 17. May 2016, 14:45
Hello I'm also trying to use the usb peak in lazarus (1.4.2 win 32) but I have not figured out how you solved. I made several attempts, using the lazarus tool by importing the example in APIs PCAN basic package but the compiler has found several errors.
Some years ago, mr. Keneth Wagner-Rivas helped me with a version for delphi 7 that works good.
In Lazarus I also tried to import this project whitout solution... other errors compiler.
Suggestions ?
Thanks, Giorgio
Compile the project, Destination: PCANBasicExample.exe: Exit code 1, Errors: 11 Warnings: 1, tips: 11
PCANBasic.pas (58.53) Note: Values ​​in enumeration types have to be ascending
PCANBasic.pas (396.35) Note: Values ​​in enumeration types have to be ascending
PCANBasic.pas (439.38) Note: Values ​​in enumeration types have to be ascending
Unit1.pas (179.46) Hint: Parameter "Action" not used
Unit1.pas (514.14) Error: Identifier not found "CreateEvent"
Unit1.pas (756.3) Error: Identifier not found "ZeroMemory"
Unit1.pas (793.3) Error: Identifier not found "ZeroMemory"
Unit1.pas (833.69) Hint: Local variable "CANTimeStamp" does not Seem to be initialized
Unit1.pas (833.55) Hint: Local variable "CANMsg" does not Seem to be initialized
Unit1.pas (849.68) Hint: Local variable "CANTimeStamp" does not Seem to be initialized
Unit1.pas (849.54) Hint: Local variable "CANMsg" does not Seem to be initialized
Unit1.pas (918.3) Error: Identifier not found "ZeroMemory"
Unit1.pas (930.69) Hint: Converting the operands to "Int64" before doing the add could prevent overflow errors.
Unit1.pas (957.5) Error: Identifier not found "TerminateThread"
Unit1.pas (973.17) Error: Identifier not found "CreateThread"
Unit1.pas (985.5) Error: Identifier not found "TerminateThread"
Unit1.pas (1019.7) Error: Identifier not found "WaitForSingleObject"
Unit1.pas (1019.49) Error: Identifier not found "WAIT_OBJECT_0"
Unit1.pas (1222.3) Error: Identifier not found "TerminateThread"
Unit1.pas (1247.33) Hint: Local variable "iBuffer" does not Seem to be initialized
Unit1.pas (1304.29) Hint: Local variable "iBuffer" does not Seem to be initialized
Unit1.pas (1413.17) Error: Identifier not found "GetCurrentDirectory"
Unit1.pas (1414.56) Warning: Local variable "szDirectory" does not Seem to be initialized
Reason: Reformatted the log for better readability.
gioazz
Postby U.Wilhelm » Wed 18. May 2016, 11:11
Sorry - as you could read in the first post - we do not official support this language - you could use our nonOOP Pascal Header to include the DLL to your project by your own.
U.Wilhelm
Previous
Return to Software
cron
OKPrivacy Policy
