PEAK PCAN-USB+ Insite Cummins_RP1210A
Postby Sergio » Mon 29. Aug 2016, 19:03
Where to find Wine driver 64 for PR1210 Insite 7.6.240. With Kalterm 3.6.4 works.
PCANRP32.INI
Configuration file for the PEAK implementation
of the Recommended Practices 1210, version A
Author: Keneth Wagner
[DeviceInformation5]
DeviceID=5
DeviceDescription=PEAK PCAN-USB
DeviceName=pcan_usb
Communication in PCan View via Cummins_Net@USB (250 kBit/s) ?
The Peak Systems PCAN-USB adapter upgrade firmware needs version 4.4 or
higher to provide optimal performance when using Calterm III. ( 2.8 - current, Can2Flash_USB.exe - no )
autodiagnosa@mail.ru
PR1210_Insite Cummins.jpg (166.01 KiB) Viewed 5165 times
Reason: Never post PEAK-System internal Documents !!!
Sergio
Re: PEAK PCAN-USB+ Insite Cummins_RP1210A
Postby Sergio » Mon 29. Aug 2016, 19:12
1
Cummins_Net (250 kBit s).jpg (57.58 KiB) Viewed 5164 times
Sergio
Postby U.Wilhelm » Mon 29. Aug 2016, 19:55
OK - but what exact is your request?
If you want to use Cummins Tools, buy from Cummins the CAN Interface. We do not send out customer special firmware.
Also never post documenst to public if you are NOT the ownwer!!
U.Wilhelm
Postby Sergio » Tue 30. Aug 2016, 05:54
Understood.
1. firmware needs version 4.4 hex
2. driver 64 for PR1210 Insite
3. Can2Flash_USB.exe
It is only Cummins ?
Tired already send requests and letters sprosboy provide Cummins Toolse.
Easier then to write a driver programmer.
On one laptop Win 86 we should Peak PCAN-USB+Insite Cummins_RP1210A. Installer driver somewhere lost.
Sergio
Postby G.Lang » Tue 30. Aug 2016, 08:13
Hello Sergio,
please download the SysInfo tool from the following URL -> http://www.peak-system.com/produktcd/To ... ysInfo.exe
Start the *.EXE (no installation required), let the analysis run and save the result as a XML file, send the XML file to info@peak-system.com
best regards
Return to Software
OKPrivacy Policy
