Learning installed driver version from registry
Postby Murat.Ocakturk » Wed 9. Nov 2016, 13:34
I want to display warning to user when installing my application, if installed PCAN driver is old in his/her PC.
I should be able to do this by writing setup script (not C++ / C#...).
Is there a possibility to get installed PCAN driver version from registry?
I read "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\Pcan_usb" node, but I couldn't see version.
Murat
Murat.Ocakturk
Re: Learning installed driver version from registry
Postby M.Maidhof » Wed 9. Nov 2016, 16:22
a simple solution will be to check the file version of Windows\system32\drivers\pcan_usb.sys
Return to Software
OKPrivacy Policy
