works okay on another PC
Postby bjlucas_utec » Wed 20. Dec 2017, 20:47
hello,
When running InitializeBasicComponents(), the bold line below "stsResult = PCANBasic.GetValue" crashes.
This code runs on other PCs. The difference. My PC was just reimaged, now runs Visual Studio 2013 now, and has all new PEAK drivers. I have a PCAN-USB Pro. The handle array looks normal with my device showing up at &h51 and &h52. I can't find any meaningful difference between my PC and other PCs where this still works. The example programs open and run ok. I cannot figure out what I forgot to update, download, or recopy back to my PC. Any ideas would be greatly appreciated.
Brad
stsResult = PCANBasic.GetValue(m_HandlesArray(i), TPCANParameter.PCAN_CHANNEL_CONDITION, iBuffer, System.Runtime.InteropServices.Marshal.SizeOf(iBuffer))
    Private Sub btnHwRefresh_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnHwRefresh.Click
        Dim iBuffer As UInt32
        Dim stsResult As TPCANStatus
        ' Clears the Channel combioBox and fill it again with
        ' the PCAN-Basic handles for no-Plug&Play hardware and
        ' the detected Plug&Play hardware
        cbbChannel.Items.Clear()
        Try
            For i As Integer = 0 To m_HandlesArray.Length - 1
                ' Includes all no-Plug&Play Handles
                If m_HandlesArray(i) <= PCANBasic.PCAN_DNGBUS1 Then
                    cbbChannel.Items.Add(FormatChannelName(m_HandlesArray(i)))
                Else
                    ' Checks for a Plug&Play Handle and, according with the return value, includes it
                    ' into the list of available hardware channels.
--->              stsResult = PCANBasic.GetValue(m_HandlesArray(i), TPCANParameter.PCAN_CHANNEL_CONDITION,
                    If (stsResult = TPCANStatus.PCAN_ERROR_OK) AndAlso (iBuffer = PCANBasic.PCAN_CHANNEL_AVAILABLE) Then
                    End If
                End If
            Next
            cbbChannel.SelectedIndex = cbbChannel.Items.Count - 1
        Catch ex As DllNotFoundException
            '        MessageBox.Show("Unable to find the library: PCANBasic.dll !", "Error!", MessageBoxButtons.OK, MessageBoxIcon.Error)
            TextBox2.Text = "PCAN initialization error"
            failcode = 1
            fail_description = "PCN init error"
            Environment.Exit(-1)
        End Try
    End Sub
Reason: Code formatted for best reading
bjlucas_utec
Re: works okay on another PC
Postby K.Wagner » Thu 21. Dec 2017, 08:00
could you please post the error message being shown by Visual Studio when the program crashes?
Postby bjlucas_utec » Thu 21. Dec 2017, 14:16
Thank you for the quick reply.
Screen shot attached.
Error on 144 board.png (168.62 KiB) Viewed 975 times
bjlucas_utec
Postby K.Wagner » Thu 21. Dec 2017, 14:37
the error message indicates that you are loading the wrong DLL within your project. You probably have a PCAN-Basic file (PCANBasic.dll) in your output folder that not match the platform of your system. If your new PC uses a 64-Bit Windows, then you should check that the PCAN-Basic file used is also 64-Bit. Same for 32-Bit systems.
You can check this by inspecting the properties of the PCANBasic.dll file
PCAN-Basic file properties - 64-Bits
Postby bjlucas_utec » Thu 21. Dec 2017, 16:56
Right on the money! Now working. Thank You!
bjlucas_utec
Return to Software
cron
OKPrivacy Policy
