how do i convert TPCANTimeStamp to a string
Postby TimK123 » Wed 28. Feb 2018, 16:50
I am writing a C# application using PCAN-BASIC API's. I need to print out as a string the value of the Timestamp that is received from the Read Function.
TPCANTimestamp Ztime;
StreamWriter sw;
result = PCANBasic.Read(PCANBasic.PCAN_USBBUS1, out msg, out Ztime);
sw.WriteLine(Ztime.ToString());
I tried doing this and it wrote to my text file this string......... Peak.Can.Basic.TPCANTimestamp
I want the timestamp to display just as it does when I use view the trace using the PCANView tool.
Tim
Reason: Code tag including for better reading
TimK123
Re: how do i convert TPCANTimeStamp to a string
Postby K.Wagner » Thu 1. Mar 2018, 10:03
the text being printed is completely right, since you are printing a structure! Please note that the actual timestamp values are within the fields of the structure which are:
  • millis
  • millis_overflow
  • micros
For instance, you have to do something like this in order to show the elapsed milliseconds:
sw.WriteLine(Ztime.millis.ToString());
Or convert the whole structure to microseconds and apply the scale you need/want, before printing the value. How to convert the TPCANTimestamp to microseconds, as well as the description of fields posted before, can be found within the help documentation of PCAN-Basic:
Help for structure TPCANTimestamp
Postby K.Wagner » Thu 1. Mar 2018, 10:14
By the way,
TimK123 wrote:I want the timestamp to display just as it does when I use view the trace using the PCANView tool.
For this, you just need to read the sample project for C#, and understand and copy the code. Just that easy...
PCAN-Basic Sample UI
Return to Software
OKPrivacy Policy
