Pcan Usb
Pcan Usb
Postby krishna » Mon 23. Apr 2018, 20:40
hello,
I wanted to create a Prototype of my system for that I'm wondering if I can assign node values to Each PCAN USB (I'm using 5 PCAN values so I wanted to assign a random 5 values ) and when we transmit data from node 1 to node 4 I should receive data at node4 saying received from node1 in receive and transmit window.
I was wondering if there is a way to achieve this?? if so kindly can you assist me to achieve this.
Thank you,
krishna
Re: Pcan Usb
Postby M.Maidhof » Tue 24. Apr 2018, 09:28
you can set device numbers into the PCAN-USB (with PCAN-View), to be able to distinguish the devices by your application. To see from which device a CAN message comes from, you should use different CAN IDs by each CAN node.
Return to Software
cron
OKPrivacy Policy
