some question about PassThru and CANFD
Pass-Thru API and connection of Pass-Thru software to PEAK CAN interfaces.
Re: some question about PassThru and CANFD
Postby uaes_hhl » Sat 8. Dec 2018, 16:22
Hi, hello, thank you very much for your reply. Can the passthru interface be able to set prescaler, tseg1and2, sync jump width, or is there a way to directly set the bit rate and sample point by passthru interface?
uaes_hhl
Postby K.Wagner » Mon 10. Dec 2018, 09:50
you can set the arbitration bitrate as a pair of BTR0/BTR1 values (WORD value) over the "BaudRate" parameter of the function PassThruConnect:
PassThruConnect(DeviceID, ProtocolID, Flags, BTR0BTR1, pChannelID).
Postby rr_iav » Wed 14. Aug 2019, 12:45
Dear Mr. Wagner
I am also interested in using a CAN-FD enabled PassThru device (Peak PCI FD in my case).
How can I obtain the PT dll for this purpose?
Thanks for you assistance.
Best regards
rr_iav
Postby U.Wilhelm » Wed 14. Aug 2019, 12:53
U.Wilhelm
Previous
Return to PCAN-PassThru API
OKPrivacy Policy
